8 years agoAltsyncram mixed port width issue
Hi, Having problems generating a simple mixed dual port RAM using M10 block memory. Using Quartus 16.1.0 Build 196, for CycloneV SX (5CSXFC6D6F31C6) FPGA. Trying to generate an Oncip Memory RAM in...
8 years agoI had same issues with u when use Qsys, mem 2 port, porta 32bits, portb 8bits. (synthesis false).
Error (272006): Cannot use port A width with port B width in altsyncram megafunction Error (287078): Assertion error: The current megafunction is configured for use with the clear box feature and cannot be used when the clear box feature is disabled Compared with file generate from IP Catalog, with same config. (systhesis ok). I figured out that issue was .byteena_a(byteenable) then I changed it to .byteena_a(4'b1111) // in this case, I use full 4byte for port a It okayed with me.
