wheelie
5 years agoALTPLL settings trouble on MAX10
Trying to generate single 96MHz uncompensated output from a 25MHz reference.
When using the parameter editor, closest it will get me is 96.022727MHz.
I would think that N=5, M=192, and C=10 would do t...
Ash_R_Altera
5 years agoHi,
You are not doing anything wrong in the settings, but somehow for this frequency 96MHz, the tool chooses the M, N and C values on its own which slightly deviates from the exact requested one. If you need the exact number, you may try cascading the PLLs and see if some settings match your requirements.
Meanwhile I will check with the tool team on this behavior.
Regards.
