altmemphy write question
May I know about the issue that you are facing? Is it in simulation or actual hardware?
Are you able to provide some snapshots of the problem?
Adzim
- lipingx2 years ago
It's actual hardware.
Let me describe issue:
step1) write data 512 bytes from address = 0
step2) write data 512 bytes from address = 512
step3) finish write data of all ddr size.
step4) read data 512 bytes from address = 0
step5) read data 512 bytes from address = 512
For expectation, all read data should be the same as write one.
but sometimes, the 1~2 bytes data of 512 bytes goes different if I done below action for write process.
1. The user logic asserts the first write request to row 0 so that row 0 is open before
the next transaction.
