18 years agoaltmemphy with 2 ram chips
hello all, Now I'm trying to implement one controller using Altmemphy to interface with two 8-bit DDR2 SDRAM chips on Stratix3.But when I share the address and control signals to both of these dev...
18 years agoThank FvM,
You guess right,but can you explain more detail about your way to fix this problem? Because I want to combine 2 8-bit DDR2SDRAM chips to 16-bit DDR2SDRAM interface so I must share address bus,control signals,... How can i do that without create these error? I need your reply as soon as possible. Thanks a lot, NPAK
