9 years agoAltLVDS_RX weird data patterns
Hello, My problem is the following: I am using the ALTLVDS_RX megafunction on a Cyclone V, without DPA, but on the side of the FPGA where dedicated SERDES circuitry is supported(on the b...
9 years agoIt seems now that the problem was that I did not set the Input Termination setting in the Pin Planner to Differential. I thought that termination would default to differential if an LVDS connection is used as it is a differential protocol, but it seems that it was not the case.
