Altera Remote Update IP block compatibility Cyclone IV/10 LP
In an older Cyclone IV design we use the Altera Remote Update IP block version 16.0. We are now looking into reusing as much as possible in a new Cyclone 10 LP design.
According to : Remote Update Intel® FPGA IP User Guide this IP should be compatible with Cyclone 10 LP. They have the same chapter for usage with exception only got Cyclone IV E than can use both parallel and serial configuration scheme.
Is Version 16 the latest version of this IP block? If any what are the differences in usage going from Cyclone IV to Cyclone 10 LP? Interfaces seems the same as far as I can see.
Link to document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altremote.pdf
- YuanLi_S_Intel
Yes, the IP is compatible between Cyclone IV and Cyclone 10 LP in the same quartus version. If you are migrating the design to newest quartus version, Quartus will prompt a message asking for migration, it will do the migration itself. Connection wise should be the same.
Bruce
- PYtte
Thank you Bruce/Yuan Li.
- YuanLi_S_Intel
i am glad it helps
