altera_parallel_flash_loader_0 vs altera-parallel_flash_loader_2
We currently using the CPLD (Max V) to configure FPGA Cyclone V
Current platform used generating a separate Config module using altera_parallel_flash_loader_0 for FPGA Configuration only / Targeted Parallel Flash: CFI Parallel Flash FPPx16 & a separate altera_parallel_flash_loader_2 for flash programming only.
Like to combine the 2 (ie FPGA configuration + Flash Programming) using just one parallel flash loader.
What is the difference between the altera parallel flash loader (altera_parallel_flash_loader) and the altera parallel flash loader II (altera_parallel_flash_loader_2) IPs?
Is the altera_parallel_flash_loader II IP a more up to date one?
Can I use the altera_parallel_flash_loader II IP one or it doesn't matter which one we use to do both FPGA configuration + Flash Programming ?
Kevin
- Knug
Contributor
altera_parallel_flash_loader vs altera_parallel_flash_loader_2 :
The Parallel Flash loader II (altera_parallel_flash_loader_2) when try to select it for Flash programming + FPGA Configuration the only Configuration schemes it gave me were AvST x8, AvST x16, AvSTx32. There were no other options to select from like the Parallel Flash loader (altera_parallel_flash_loader) one did.
The altera_parallel_flash_loader one was able to select FPPx16, so decided to use this IP to do both Flash Programming + FPGA Configuration.
Please comment here.
Kevin
- Ash_R_Altera
Hi Knug,
For Cyclone V device configuration, you can use Parallel Flash Loader IP only.
Parallel Flash Loader II IP uses Avalon-stream which supported only by Stratix 10 devices.
Parallel Flash Loader IP can be used for the flash programming as well.
Regards.
- Ash_R_Altera
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
