Knug
Contributor
5 years agoaltera_parallel_flash_loader_0 vs altera-parallel_flash_loader_2
We currently using the CPLD (Max V) to configure FPGA Cyclone V
Current platform used generating a separate Config module using altera_parallel_flash_loader_0 for FPGA Configuration only / Ta...
Ash_R_Altera
5 years agoHi Knug,
For Cyclone V device configuration, you can use Parallel Flash Loader IP only.
Parallel Flash Loader II IP uses Avalon-stream which supported only by Stratix 10 devices.
Parallel Flash Loader IP can be used for the flash programming as well.
Regards.
