Knug
Contributor
5 years agoaltera_parallel_flash_loader_0 vs altera-parallel_flash_loader_2
We currently using the CPLD (Max V) to configure FPGA Cyclone V
Current platform used generating a separate Config module using altera_parallel_flash_loader_0 for FPGA Configuration only / Ta...
Knug
Contributor
5 years agoaltera_parallel_flash_loader vs altera_parallel_flash_loader_2 :
The Parallel Flash loader II (altera_parallel_flash_loader_2) when try to select it for Flash programming + FPGA Configuration the only Configuration schemes it gave me were AvST x8, AvST x16, AvSTx32. There were no other options to select from like the Parallel Flash loader (altera_parallel_flash_loader) one did.
The altera_parallel_flash_loader one was able to select FPPx16, so decided to use this IP to do both Flash Programming + FPGA Configuration.
Please comment here.
Kevin
