14 years agoAltera Offload UDP IP-How to change Minimum Packet Size
Hi, I'm trying to use Altera UDP Offload IP for my project. But the minimum packet size is 46, the minimum UDP payload is 18 bytes. This is a limitation. If the UDP payload is less than 18 byt...
14 years agoThanks.
This thread is closed. David
