14 years agoAltera Offload UDP IP-How to change Minimum Packet Size
Hi, I'm trying to use Altera UDP Offload IP for my project. But the minimum packet size is 46, the minimum UDP payload is 18 bytes. This is a limitation. If the UDP payload is less than 18 byt...
14 years agoThe 46 minimum packet size is due to Ethernet physical medium.
AFAIK this derives from collision detection requirements, since this is the minimum frame length which guarantees that overlapping frames are discovered.
