9 years agoAltera FIR Compiler II 15.0 Coefficients Reload Issues
For the last couple of days I've been trying to get the Altera FIR Compiler II Qsys core to work with coefficient reloading, with no success until now. I'm posting this for reference if anyone else f...
8 years agoHello,
I am also working with the FIR compiler and there still seems to be an issue with coefficient reloading (18.0). When I try to read a coefficient the whole Nios system hangs/deadlock. I assume that it waits for the valid signal of the MM slace interface that never arrives (I still need to do some further investigation). Anyway the line "add_interface_port coeff_reset coeff_in_areset reset_n Input 1" is still the same in Version 18.0, so I tried your fix. However, now I am no longer able to program the processor. When ever I try, it says: Using cable "USB-Blaster [1-8.3]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused Output of nios2-download Did you ever experience such a behaviour?
