17 years agoALT2GXB loopback problem
Hi, I'm using an Arria EP1AGX60CF484C6 with an ALT2GXB core configured in XAUI mode (4 lanes). I'm trying to do a loopback to test it out. The loopback is in the core, so what I've done is con...
17 years agoThanks again. I'll get that calibration part hooked up.
Do you have any more information on what this actually means: "Synchronization is performed after any reset condition. You must determine when the data is valid after reset (for example, by using the rx_syncstatus signal). Table 2–52 shows the blocks affected by each reset and power-down signal." If it is done by the GXB, then I would imagine, after reset, I can't enable loopback in the FPGA until the rx_syncstatus signal is high? Is it recommended to use the pll_inclk (which is on the REFCLK0 pin) directly i.e. can I use it to drive logic? Do the tools automatically put me on clock cline or do I have to instantiate a special buffer? I want to tap the incoming PLL clock since it's always going to be on.
