17 years agoALT2GXB loopback problem
Hi, I'm using an Arria EP1AGX60CF484C6 with an ALT2GXB core configured in XAUI mode (4 lanes). I'm trying to do a loopback to test it out. The loopback is in the core, so what I've done is con...
17 years agoThe transceivers in SIIGX and AGX have the same architecture so I guess you can use the same reset sequence.
The cal_blk_clk may well affect your circuit behaviour as this clock is required to calibrate tha On-Chip Termination. You should connect this up.
