17 years agoALT2GXB loopback problem
Hi, I'm using an Arria EP1AGX60CF484C6 with an ALT2GXB core configured in XAUI mode (4 lanes). I'm trying to do a loopback to test it out. The loopback is in the core, so what I've done is con...
17 years agoThanks for the info.
I couldn't find any information about the reset order. I read it on some other site and used it. Thanks for clarifying that. Right now, all I want to do just get this link up working with this external switch hence the reason I did the loopback in the core. Unless, there is something missing that isn't in the datasheets, I thought it would be simple enough to tie the tx and rx databuses/ctrl lines in the FPGA core and it should work. Sounds like there is something else that needs to be done here. MT
