Agilex5 GTS Reset Sequence
- 1 year ago
Referring back to your initial observation that suggests a possible FPGA configuration failure, I believe it’s important to isolate this issue first.
Would you be able to try programming the device directly via JTAG to confirm whether the FPGA can be successfully configured? From my understanding, the XCVR reset typically does not impact FPGA configuration, as the transceiver logic only starts operating after a successful configuration.
Unless the message “FPGA reconfiguration failed” is referring to something else (e.g., a soft reconfiguration or user logic indication), it may not be a true configuration failure.
Please let me know if you have any concerns or need further assistance. Thank you!
Chee Pin
Sorry for the delay. As I look at your reset codes, there seems to be no anomaly with the de-assertion following the timing diagram. To ensure we are on the same page, just would like to check with you on the following:
1. I notice that your printout seems to mention about "FPGA reconfiguration failed". As I understand it, XCVR reset is generally not directly affecting the FPGA configuration. Would you mind to further elaborate on the steps taken to get to this error?
2. Just wonder if you are using any Altera devkit?
3. Just to check if you are using any example design generated from Quartus? If yes, please let me know the specific design that you are using.
Thank you.
Hi @CheePin_C_Intel!
Thanks for your response I will try to answer:
1: The following is my qsys design:
... // GTS signals wire gts_i_rx_cdr_refclk; wire gts_i_tx_pll_refclk; reg gts_i_tx_reset, gts_i_rx_reset; wire gts_o_tx_reset_ack, gts_o_rx_reset_ack; wire gts_i_tx_coreclkin, gts_i_rx_coreclkin; wire gts_o_tx_clkout, gts_o_rx_clkout; wire gts_o_tx_serial_data, gts_o_tx_serial_data_n; wire gts_i_rx_serial_data, gts_i_rx_serial_data_n; wire [79:0] gts_i_tx_parallel_data; wire [79:0] gts_o_rx_parallel_data; wire osc_clk; wire osc_rst; wire [31:0] osc_pattern_o; wire raw2s_clk; wire raw2s_rst; wire [31:0] raw2s_data_i; assign gts_i_tx_coreclkin = gts_o_tx_clkout; assign gts_i_rx_coreclkin = gts_o_rx_clkout; //assign gts_i_tx_parallel_data[38] = 1'b0; // TX PMA Interface Data Valid assign gts_i_tx_parallel_data[31:0] = osc_pattern_o; assign raw2s_data_i = gts_o_rx_parallel_data[31:0]; assign gts_i_rx_serial_data = gts_o_tx_serial_data; assign gts_i_rx_serial_data_n = gts_o_tx_serial_data_n; always @(posedge system_clk_100) begin if (system_reset) begin gts_i_tx_reset <= 1'b1; gts_i_rx_reset <= 1'b1; end else begin if((gts_o_tx_reset_ack==1'b1) && (gts_o_rx_reset_ack==1'b1)) begin gts_i_tx_reset <= 1'b0; gts_i_rx_reset <= 1'b0; end end end //// Oscillator assign osc_clk = gts_o_tx_clkout; assign osc_rst = system_reset; // Qsys Top module qsys_top soc_inst ( ... .intel_directphy_gts_1_i_rx_cdr_refclk_p_clk (REFCLK), .intel_directphy_gts_1_i_tx_pll_refclk_p_clk (REFCLK), .intel_directphy_gts_1_i_tx_reset_tx_reset (gts_i_tx_reset), .intel_directphy_gts_1_i_rx_reset_rx_reset (gts_i_rx_reset), .intel_directphy_gts_1_o_tx_reset_ack_tx_reset_ack (gts_o_tx_reset_ack), .intel_directphy_gts_1_o_rx_reset_ack_rx_reset_ack (gts_o_rx_reset_ack), .intel_directphy_gts_1_i_tx_coreclkin_clk (gts_i_tx_coreclkin), .intel_directphy_gts_1_i_rx_coreclkin_clk (gts_i_rx_coreclkin), .intel_directphy_gts_1_o_tx_clkout_clk (gts_o_tx_clkout), .intel_directphy_gts_1_o_rx_clkout_clk (gts_o_rx_clkout), .intel_directphy_gts_1_o_tx_serial_data_o_tx_serial_data (gts_o_tx_serial_data), .intel_directphy_gts_1_o_tx_serial_data_n_o_tx_serial_data_n (gts_o_tx_serial_data_n), .intel_directphy_gts_1_i_rx_serial_data_i_rx_serial_data (gts_i_rx_serial_data), .intel_directphy_gts_1_i_rx_serial_data_n_i_rx_serial_data_n (gts_i_rx_serial_data_n), .intel_directphy_gts_1_i_tx_parallel_data_i_tx_parallel_data (gts_i_tx_parallel_data), .intel_directphy_gts_1_o_rx_parallel_data_o_rx_parallel_data (gts_o_rx_parallel_data), .intel_srcss_gts_1_i_src_rs_priority_src_rs_priority (1'b1), .oscillator_0_clk_clk (osc_clk), .oscillator_0_rst_reset (osc_rst), .oscillator_0_oscillator_pattern_o_new_signal (osc_pattern_o), .raw_to_stream_1_raw_data_in_i_new_signal (raw2s_data_i), ... ); ...
I then generate the HDL, and compile the bitstream - and load over TFTP.
2: Using this devkit
3: This is not an example design generated from Quartus - I am having trouble there too (different thread for that topic)
