Agilex 5 SDI 148.5 and 148.35 MHz refclks
- 3 months ago
Hi yuriah726 ,
If I am going to have my own board instead of a devkit, then I will need to provide the FPGA with a reference clock signal that is multiplexed between 148.5 and 148.35 MHz, as well as implement the multiplexing control. Is this correct?
>> Yes. For Agilex 5 TX-only SDI, the expected approach is to externally select either 148.5 MHz or 148.35 MHz and feed that selected clock to the transceiver reference clock input.
Is there a way to provide both reference clocks to the IP and switch between them internally?
>> No. There is no Agilex 5 SDI II IP option in Quartus for internal switching between two reference clocks.
Hope this clarified.
Wincent_Altera
Hi Wincent_Altera,
I just want to make sure I am understanding correctly.
There isn't a way to provide both reference clocks to the IP and switch between them, or provide one and generate the other from it?
Once again, this is for transmitting SDI data, not receiving, so I'm not trying to detect whether the framerate is being sent to me as fractional or integer, but rather make the framerate I am transmitting be fractional or integer.
Thank you very much for all of your help,
Yuriah
Hi yuriah726 ,
Wincent_Altera
