TakaU's avatar
TakaU
2 hours ago
Agilex™ 7 I-Series FPGA Transceiver SoC Development Kit GSRD Build
I am attempting to build the GSRD using the Intel® Agilex™ 7 I-Series FPGA Transceiver SoC Development Kit (4x F-Tile) DK-SI-AGI027FA.
Quartus Version: 24.3.1
Reference Document:
https://altera-fpga.github.io/rel-24.3.1/embedded-designs/agilex-7/i-series/soc/gsrd/ug-gsrd-agx7i-soc/
When running the "Build Hardware Design" procedure according to the instructions:
make BOARD_TYPE=devkit_fm87 BOARD_PWRMGT=linear QUARTUS_DEVICE=AGIB027R31B1E1V ENABLE_HPS_EMIF_ECC=1 FPGA_SGPIO_EN=1 HPS_F2S_IRQ_EN=1 generate_from_tcl all
It throws the following log error and fails to proceed:
make[1]: *** [Makefile:817: qsys_generate_qsys] Error 1
make[1]: Leaving directory '/home/nict/p.agilex7_gsrd/gsrd.dk_si_agi027fa/agilex_soc_devkit_ghrd'
make: *** [Makefile:833: generate_from_tcl] Error 2
Could you please advise what might be causing this issue, or let me know which logs (such as QSYS/Platform Designer logs) I should check?
1 Reply
  • TakaU's avatar
    TakaU
    Please delete this post as it was posted by mistake / contained incorrect information. Thank you.
