16 years agoAddress map for 2 masters
Good afternoon, I've been reading for a long time in this forum, and I have resolve all my problems with it, but now I have a question that I have not seen here. I'm sharing a SRAM chip with a NIO...
16 years agoHi both,
Thank you four your reply. Then, if I'm correct, I can change the "LENGTH" parameter in my generated.x document and use it as my custom script? Then I understand that the NIOS, when compile, will take it in account and will use the area defined in the generated.x file. It's correct? Thank you for your support. Isaac Campos
