18 years agoaddress alignment during master write bursts?
Moin, Have some strange behaviour right here: I'm using QII6.1 and the CyclonII-NIOS-Evalboard; have built a sopc containing (besides other things) a PLL generating the clock of 85MHz, NIOS...
18 years agoMoin,
Hmmm, not much response yet: Nobody else having such kind of problems? Or is the solution much too obvious to post here? :) I've solved it so far by using an initial burst with length 1-3 (or no initial burst, if the address ist already aligned) and then proceeding with 16xfer bursts, but i would feel much better if i'd had some specification somewhere, describing the burst abilities of avalon components. Cheers WK
