12 years agoAccessing image stored in SDRAM sent through PCIex from Intel Atom host on DE2i-150
Hi all, i am currently working on hardware accelerator for a gesture recognition application on DE2i-150. Hope there is anyone can help me on my problems written below. I have successfully se...
12 years ago --- Quote Start --- You can use the Frame Reader component, as you have already included in your system. It will read the image data from SDRAM and supply it in Avalon-ST stream format to your (new) IP block which can then process it. --- Quote End --- Thanks for your reply=) I will try on it. BTW, this is actually a demo given in the DE2i-150 CD. (...\de2i-150\Demonstrations\FPGA\PCIE_Display) It seems like this demo can't read the data from SDram and write data to SDram at the same time.. Is there any way to do simultaneous read/write operation on SDram? https://www.alteraforum.com/forum/attachment.php?attachmentid=8842
