8 years agoAccessing DDR-Ram from FPGA on DE1-SoC
Hi, I’m trying to write data directly to the HPS DDR3-RAM on my eval board. Problem is, I’m quite new to FPGAs in general and so after a bit of research I ended up with the following idea: I t...
8 years agoHi cyano Im working in a project and I need too to write data to HPS DDR3 .I found an exemple to whrite in DDR3 memory https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/writing_to_hps_memory my problem when i type the command memtool on putty terminal it returns command not found ,should I install some software package to run this command ?? I try to install some packages but the command apt get gives also command not found.Pllz need your help im newbie in linux and putty terminal......
