8 years agoabout the IP core legacy EPCS/EPCQx1 Flash Controller does not support cyclone 10LP
:confused:
I'm confused about this IP core, because it doesn't support my new FPGA cyclone 10LP. Can someone give me any advise?5 Replies
Yes, It's is not supported. Check the link which addresses the same issue. https://www.alteraforum.com/forum/showthread.php?t=58035 Alternate are ASMI Parallel IP or ASMI Parallel II IP which has a similar feature https://www.altera.com/en_us/pdfs/li...i_parallel.pdf https://www.altera.com/content/dam/a...g/ug-asmi2.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
I'm so sorry to reply you after so long time. As a fresh hand, because I regard the username as the Email address, I can't log in until now. And I 'm preparing exams these days, so I always forget it. After reading the addresses, I figure out it. Thanks for your help~
Best wishes, MelonEater (An undergraduate from China) - Altera_Forum
Hello, I find that Quartus18.0 still don't support this IP. But it said this would be solved in 18.0 in this address "https://www.alteraforum.com/forum/sh...ad.php?t=58035".
The document has been updated. Check the link session 15.1-> Note https://www.altera.com/en_us/pdfs/literature/ug/ug_embedded_ip.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Thank you very much, I will look it up carefully later!
Best wishes.
