14 years agoabout Merlin Burst Adapter
Hello, Now I'm writing an interface between Avalon bus and a LSI, changing Avalon bus signals(read, write,ect) to LSI control signals. An interface can deal with burst transfer is preferred. ...
14 years ago --- Quote Start --- Now I'm writing an interface between Avalon bus and a LSI, changing Avalon bus signals(read, write,ect) to LSI control signals. An interface can deal with burst transfer is preferred. --- Quote End --- Are you sure you need burst? Does the LSI interface use a start address followed by multiple data phases like a DDR, or can it just accept data on every cycle? If the latter is the case, then the Avalon components can post writes and prefetch reads on every clock cycle, so a burst interface is not required. Can you post a part number for the LSI device. I'll take a look. Cheers, Dave
