about fft ip core
I'v read the document about the fft ip core(ug_fft.pdf), the document says "For single engine output FFT/IFFTs, there is an additional factor of Q and the shift must be
2-exponent – Q, where Q = 1 for an even power of 2 and Q = 2 for an odd power of 2." I don't know how to choose the value of Q for the single engine output FFT or what's the meaning of "where Q = 1 for an even power of 2 and Q = 2 for an odd power of 2" For example , 1)if I use 1024 point single engine FFT and the output of exponent scaling values is -11. Should I choose Q=1? and the shift will be 2^10? 2)if I use 512 point single engine FFT and the output of exponent scaling values is -11. Should I choose Q=2? and the shift will be 2^9?8 Replies
Sounds like it should be this way...
512 points = 2^9 exponent points, therefore: => exponents = 9 => Q = 2 Therefore, shift amount = 2^(-exponent-Q) = 2^-11 1024 points = 2^10 points, thherefore: => exponents = 10 => Q = 1 Therefore shift amount is also 2^-11 - Altera_Forum
Also another good place to check out the scaling scheme is AN Application Note# 404. In fact I was able to use that Application note to create a unity gain example. (The design, built in 6.1, should be up somewhere on the forum.)
Can somebody provide a simple example of how to use Altera's FFT IP core?
Here is a FFT example (with DSP Builder) that I did a while back (back in 6.1), to test out the block floating point equation. Hope this helps...
Thanks for the quick reply. But what am I supposed to do with it?
Do u have DSP Builder (version 6.1)? If u do... then u simply need to bring up the model and reinstantiate all the megacores. If you don't have DSP Builder v6.1, then I suppose you can just look at the sample test bench. That should give you some hints regarding the FFT core...
Is the DSP builder part of Quartus II or Nios II IDE? I have the Quartus II and Nios II IDE.
It is really a separate platform that is built on top of Simulink/Matlab. DSP Builder calls Quartus from the back end... You can probably find more info on DSP Builder on Altera website: http://www.altera.com/products/software/products/dsp/dsp-builder.html
