JET60200
Contributor
5 years agoA10 CPRI IP MII - how to instantiate cpri (MII) and how select FPGA MAC IP to connect it ?
hello,
we are using Arria10 GX device, and we are using CPRI IP v7.0 in our project.
CPRI DATA Path has been verified OK, and the next step we wantsto verify is cpri "C&M" Path, which accordin...
CheepinC_altera
5 years agoHi,
For the CPRI MII interface, it is an Ethernet interface. However, since I am not an Ethernet expert, I could not comment which specific Ethernet IP to use. As long as the interface comply with MII specs, then it should be fine.
Regarding your latest inquiries related to the PCIe endpoints, it would be great if you could help to open a new case so that our PCIe expert could further assist. You may let me know the case after created, I can help to notifiy the PCIe team to expedite the routing.
