18 years agoa problem about ad ip core
Hello everybody, I run into a problem about ad ip core for TLC549 which is made by myself.When I only debug .vhd files,the result is right,the output is 8-bit A/D value;while I use nios...
18 years agoThe problem has been solved by myself,thank you all the same.
