A design based on the PCIe DMA transfer example design for Arria 10 device.
Hi @Sijith,
In order to see the nodes, please ensure that you complete the correct pin assignment in the Pin Planner and compile the project beforehand.
Besides creating a Signal Tap Instance by HDL Instantiation, you can create the Signal Tap instance using the Signal Tap GUI.
Please refer to the steps in Section 2.3.1 to create a Signal Tap instance with the Signal Tap logic analyzer GUI.
User Guide: https://www.intel.com/content/www/us/en/docs/programmable/683819/23-4/faq.html
VenTing_Intel
- Sijith2 years ago
Hi VenTing,
Correct pin assignment you meant is for the modified design, right? I have the pin assignment for the modified design (you can see that if you could open the ModifiedDesign file I shared you previously). And I assume I may not need to work on the pin assignment just after adding the Signal Tap IP into the design in the Platform Designer?
I have a pin assignment (as I mentioned above I did not change any pin assignment after adding Signal Tap IP to the design) and did compile it too. But looks something is still missing.
I went through the document and what I could understand is, we can add Signal Tap instances using GUI (So here we dont need to add signal tap IP to the Platform designer system) . Please correct me if I got wrong?
Looking forward for your reply. Thank you.
