ushermark's avatar
ushermark
3 years ago
2S2Rx8 (3DS) RDIMM EMIF IP calibration
Hello.
I am wonder if it is possible to pass EMIF RAM calibration on Arria 10 FPGA for 2S2Rx8 ECC memory using non-3DS type like 2Rx8 RDIMM ECC. I know that Arria 10 doesn't support 3DS memories, but the only difference seems to be in Chip ID signal (C0...C2). Therefore, can I overcome this restriction or 3DS memories use different calibration algorithms?
Memory sample used for tests: Micron MTA72ASS8G72PSZ-2S6.
Mark
  • Hi Mark,
    "Is it possible to implement own hard memory controller in Quartus project? Or it is a part of hardware specification for FPGA?"
    • Yes you can implement your own memory controller as soft memory controller with hard PHY.
    • In the General tab of EMIF IP, there is a configuration option that allow you to choose a Hard PHY and Hard Memory Controller.
    • Somehow it's depends on memory standard as well.
    Adzim
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi Mark,
    Thank you for your question.
    As you well known that the Arria 10 DDR4 does not support 3DS memory.
    I already check with engineering regarding this matter and they have feedback with below point.
    • This is due to the Arria 10 does not have support for the Chip ID bits required.
    • Plus the hard memory controller does not support 3DS and the Chip ID bits.
    Adzim
    • ushermark's avatar
      ushermark
      Hello Adzim,
      I do have a follow-up question. Is it possible to implement own hard memory controller in Quartus project? Or it is a part of hardware specification for FPGA?
      Mark
    AdzimZM_Altera
    Hi Mark,
    Adzim
    AdzimZM_Altera
