ushermark
3 years ago2S2Rx8 (3DS) RDIMM EMIF IP calibration
Hello.
I am wonder if it is possible to pass EMIF RAM calibration on Arria 10 FPGA for 2S2Rx8 ECC memory using non-3DS type like 2Rx8 RDIMM ECC. I know that Arria 10 doesn't support 3DS memories, ...
- 3 years ago
Hi Mark,
"Is it possible to implement own hard memory controller in Quartus project? Or it is a part of hardware specification for FPGA?"
- Yes you can implement your own memory controller as soft memory controller with hard PHY.
- In the General tab of EMIF IP, there is a configuration option that allow you to choose a Hard PHY and Hard Memory Controller.
- Somehow it's depends on memory standard as well.
Adzim
AdzimZM_Altera
3 years agoHi Mark,
Thank you for your question.
As you well known that the Arria 10 DDR4 does not support 3DS memory.
I already check with engineering regarding this matter and they have feedback with below point.
- This is due to the Arria 10 does not have support for the Chip ID bits required.
- Plus the hard memory controller does not support 3DS and the Chip ID bits.
Adzim
ushermark
3 years agoHello Adzim,
I do have a follow-up question. Is it possible to implement own hard memory controller in Quartus project? Or it is a part of hardware specification for FPGA?
Mark
