14 years ago2D Median Filter in MegaWizard
Hi, I am working on doing background subtraction with DE2 development board and I want to do a noise filtering using the median filter 2D megacore function which comes with the quartus II 11.1sp1 Web...
14 years agoYou will need to make sure that your input conforms to the Avalon-ST Video data format, as specified in the Video & Image Processing Suite User Guide (you can find this online). The output will also use this standard. Both the input and output use a 1 cycle ready-latency handshake protocol where the input valid may only be high on clock cycles that come 1 clock cycle after the ready was high.
