14 years ago2D Median Filter in MegaWizard
Hi, I am working on doing background subtraction with DE2 development board and I want to do a noise filtering using the median filter 2D megacore function which comes with the quartus II 11.1sp1 Web...
14 years agothe VIP suite cores are a bit "weird", the source HDL doesn't actually fill up with code, just comments for something that's generated during compilation
are you able to compile successfully? if not, see the errata, there's a known issue about generating and compiling the VIP Suite cores on Windows Vista and 7. the work around is running Quartus as Administrator to generate and compile the VIP Suite cores
