Rolf_2
5 years ago10 Gig Ethernet on Arria 10 product.
Hi all,
I am working on a board that will use the 10G Ethernet in the Arria 10AX057K2F40I1HG part.
Is there a "best" pinout for the pins used for the 10G Ethernet port?
Cheers,
Rolf
Deshi_Intel
5 years agoHi,
All transceiver channel is designed with equal performance.
We only differential the Arria 10 transceiver channel by type and not by transceiver pin location.
- GX transceiver channel can meet certain performance
- GT transceiver channel can meet certain performance
- Detail to be found in Arria 10 datasheet
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_datasheet.pdf
Using Gx transceiver channel is sufficient for 10G application
dlim
