14 years ago[ NCO ] numerically controlled oscillators
Hi, i have simulated this NCO IP using small ROM options.Then i run the tcl script to simulate the waveform in modelsim. Now was it possible to display this sin and cos waveform on the oscillo...
14 years agoI am not sure, check the datasheet of the DAC. Should be enough, since vga driver needs to generate vertical and horizontal timing impulses, which are not needed in this case.
