17 years ago.mif file generation of perticular freuency
hi, i am facing a problem to generate a .mif file of perticular frecuency for initializing the ROM in my tone generation project...can anybody help me regarding this...
17 years ago --- Quote Start --- If it was me, I will generate my own mif using ant tool and simply read out in firmware - a very basic module. --- Quote End --- Why use a different tool when VHDL can do this for you? I suppose if you are using NIOS II this makes sense, but without it I don't quite follow how you would read it out? It is true that you may only require a few points to generate a tone depending on the quality of the tone that is needed.
