13 years ago
Yocto for Cyclone V
current Yocto release for Altera Cyclone V is the Danny release.
When will there be a Dylan release?
Kirby
    my post with URLs has not shown up yet, so look on rockboards org site under git dylan-altera and get the snapshot.
    Kirby
    hi kirby, could you be more precise where we can find the snapshots?
    You can find the snapshots at:
    http://git.rocketboards.org/poky-socfpga.git/ (http://git.rocketboards.org/poky-socfpga.git/)
    Look for the build you want and click on the snapshot link and it will prompt you to download a .tar.gz
    Then uncompress them into the directory you want to and then follow the bitbake procedure:
    http://www.rocketboards.org/foswiki/documentation/alterasocdevelopmentboardyoctogettingstarted
    hob is still having issues.
    Kirby
    Hi all,
    Did anybody get perf tool to build? it fails to find libelf.h.. What am I doing wrong?
    Thanks for your quick response<85> Below the steps I have been using.
    Look forward to your help on this issue..
    Suresh
    $ cd ~
    $ git clone http://git.rocketboards.org/poky-socfpga.git
    $ cd poky-socfpga/
    $ git checkout -b <test_branch> ACDS14.0_REL_GSRD_PR
    $ source ./altera-init build
    $ bitbake perf
    Note: replace <test_branch> with the name of the branch you want to use locally.
    This fails with
    [snagarajan@moltar-76 perf]$ alias armmake='make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm'
    [snagarajan@moltar-76 perf]$ PATH=~/gcc-linaro-arm-linux-gnueabihf-4.9-2014.07_linux/bin:$PATH
    [snagarajan@moltar-76 perf]$ armmake install
    BUILD: Doing 'make -j4' parallel build
    Auto-detecting system features:
    ... backtrace: [ on ]
    ... dwarf: [ on ]
    ... fortify-source: [ on ]
    ... glibc: [ on ]
    ... gtk2: [ OFF ]
    ... gtk2-infobar: [ OFF ]
    ... libaudit: [ on ]
    ... libbfd: [ on ]
    ... libelf: [ on ]
    ... libelf-getphdrnum: [ on ]
    ... libelf-mmap: [ on ]
    ... libnuma: [ OFF ]
    ... libperl: [ on ]
    ... libpython: [ on ]
    ... libpython-version: [ on ]
    ... libslang: [ OFF ]
    ... libunwind: [ OFF ]
    ... on-exit: [ on ]
    ... stackprotector: [ on ]
    ... stackprotector-all: [ on ]
    ... timerfd: [ on ]
    config/Makefile:329: No libunwind found, disabling post unwind support. Please install libunwind-dev[el] >= 1.1
    config/Makefile:368: slang not found, disables TUI support. Please install slang-devel or libslang-dev
    config/Makefile:381: GTK2 not found, disables GTK2 support. Please install gtk2-devel or libgtk2.0-dev
    config/Makefile:536: No numa.h found, disables 'perf bench numa mem' benchmark, please install numa-libs-devel or libnuma-dev
    FLEX util/pmu-flex.c
    CC util/environment.o
    CC util/event.o
    CC util/evlist.o
    In file included from util/callchain.h:8:0,
    from util/hist.h:6,
    from util/evsel.h:11,
    from util/evlist.h:8,
    from util/evlist.c:15:
    util/symbol.h:17:20: fatal error: libelf.h: No such file or directory
    # include <libelf.h>
    compilation terminated.
    make[1]: *** [util/evlist.o] Error 1
    make[1]: *** Waiting for unfinished jobs....
