14 years ago
Yes No question (Using FPGA as a wire)
1-Can I use FPGA, just as a wire, to carry a bidirectional line like I2C SDA from one pin of the FPGA to the other pin of the FPGA. In the FPGA there will not be an i2c master or slave it will just route the signal from one side to the other side. Both of the sides should be able to drive the SDA signal(bidirectional)
WHY :
I2c master and i2c slave is not physically connected to each other on the PCB BOARD. But they are physically connected to FPGA (Cyclone II EP2C20F484C8)
    Not sure that can work for bidirectional data.
    Any kind of buffer has to know the data direction.
    I don't know about Xilinx - wouldn't touch it with a bargepole :)
    I use a component in my VHDL code:
    LIBRARY altera;
    	USE altera.altera_primitives_components.all;
    odsda : opndrn
    		port map (
    				a_in	=> dp_SDaOut ,
    				a_out	=> Sda
    Don't know how to do this in Verilog - wouldn't touch that with a bargepole either :)
    Dear Josyb. You answer is digitally appropriate :)
    Could you guide me on this.
    Is there an IO buffer in altera like in Xilinx?
    Do I need to use Megafunction?
