12 years agoXilinx .XCO = Altera's ???
When creating an IP with Xilinx a .xco file is generated that lists all of the parameters the core uses. Does Altera generate a similar file? I can't find one. The closest thing is the Matlab file...
12 years ago --- Quote Start --- When creating an IP with Xilinx a .xco file is generated that lists all of the parameters the core uses. Does Altera generate a similar file? I can't find one. The closest thing is the Matlab file when "some" information can be obtained. --- Quote End --- matlab has nothing to do with what you are after. Unlike the mess of xilinx and its cluttered files. Altera generates a vhdl wrapper (or verilog) and can be used for synthesis or sim
