WYSIWYG documentation
Is there documentation available for the WYSIWYG components (eg twentynm_clkena, twentynm_ddio_out)? If not, where can one find the verilog source?
Hung
Can you try using this path and see?
quartus/libraries/megafunctions/xml_info/twentynm_clkena_info.xml
Because I managed to open it at my end.
Ven Ting
- VenT_Altera
Ven Ting
- VenT_Altera
- HMai
Thanks Ven Ting, twentynm_ component parameters and ports are available at this location.
Hung
- VenT_Altera
Ven Ting
- HMai
Ven Ting,
Search for *twentynm_clkena* does not return any results
Search for *twentynm" returns some files (below) but none has the twentynm_clka component.
twentynm_io_12_lane_*
twentynm_xcvr_*
twentynm_pma.sv
twentynm_pcs.sv
Tool used is Quartus Prime Pro Version 22.1.0 Build 174 03/30/2022 SC Pro Edition for windows. Please send more ideas.
Hung
- VenT_Altera
You may go to File > Open in Quartus and search for e.g. twentynm_clkena in the directory where you installed the Quartus.
Ven Ting
- HMai
Thanks, where can I look at the HDL to check IO information such as parameters and port names?
Hung
- VenT_Altera
We do not provide documentation for WYSIWYG components.
You may checkout the Intel® Quartus® Prime Pro and Standard Software User Guides if it helps.
Ven Ting
