14 years agowrong device ID by auto-decect in Quartus2
Hi everybody!
I'm Trying to program EP4SGX180 device in JTAG inderect mode,but I got the error as follows: Error: Can't configure device. Expected JTAG ID code 0x024210DD for device 1,but found JTAG ID code 0x024020DD. Then I open programmer tool and click "auto-detect" instruction.The device detected by Quartus2 unexpectedly is ER4SGX360(its ID CODE just is 0x024020DD). I ensure the various voltage up to the specification and the USB-Blaster cable OK. I want to know what reason should cause above mentioned phenomenon. Thanks in advance!2 Replies
It's rather unlikely, that the JTAG interface transmits two ID bits continuously wrong, although possible. The said numbers are correct according to quartus/bin/pgm_parts.txt, the ID list used by Quartus.
Did you try to program the device as GX360? P.S.: You have been talking about JTAG indirect programming. The problem should happen in all JTAG accesses? Does it? - Altera_Forum
You may have assigned a different device in Quartus compared to what you are programming:
http://bsdl.info/details.htm?sid=958a96809e5673c588ca59b002289d77 http://bsdl.info/details.htm?sid=6d7b89a0cec9f33a88ca59b002289d77
