14 years agoWriting to EPCS device from Serial Flash Loader & SPI IP core
I have a working hardware design whith Cyclone IVe. Inside the FPGA we have an SPI peripheral which reads and writes from/to any standard SPI bus. This IP core has been validated in dozens of o...
14 years ago --- Quote Start --- Is there a reference design anywhere that shows that "use as regular I/O" working? --- Quote End --- I've tested this feature on a DE0-nano and it worked fine. I configured a JTAG-to-Avalon-MM master with PIO per the tutorial I wrote here: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial and then bit-banged a few SPI Flash transactions to read/write/program/erase the EPCS device on the DE0-nano. I have some Spansion SPI flash devices that I plan on testing, but haven't got around to that yet. Try a simple test, where you select the pins as "Use as regular I/O" (that option is under Assignments->Device, Device and Pin Options, Dual-purpose pins), and then just assign static values to the outputs. Make sure you get MISO and MOSI assigned correctly. I had them backwards the first time I did a design, and synthesis failed. Cheers, Dave
