15 years agoWrite Protection issue on EPCS
Hi, I'm using CyclonIII with standard AS configuration scheme with EPCS64.
My project includes writing/reading parameters to/from EPCS Flash memory by NIOS. How can I protect Configuration Image on EPCS Flash from accidental overwriting? Thanks.4 Replies
Could you possibly point me at this topic in the forum? I've not found it.
I think, the protection can be changed in the flash programmer tool, it has been discussed in the forum before.
Thank you for your response.
Yes, I know about this register but I don't realy want to alter EPCS Controller design in order to access this register. Is there another way to config this reg? - Altera_Forum
EPCS flash devices have a block protection feature which helps to prevent unintentional data overwriting. You can select the protected blocks through a 3-bit configuration in status register.
Refer to the EPCS datasheet, page 16 and following.
