15 years agoWrite Protection issue on EPCS
Hi, I'm using CyclonIII with standard AS configuration scheme with EPCS64. My project includes writing/reading parameters to/from EPCS Flash memory by NIOS. How can I protect Configurati...
15 years agoEPCS flash devices have a block protection feature which helps to prevent unintentional data overwriting. You can select the protected blocks through a 3-bit configuration in status register.
Refer to the EPCS datasheet, page 16 and following.
