Paul_S
3 years agoWrite-protect configuration flash memory with Quartus Prime Pro Programmer
In our design we use a Micron MT25QU256 flash memory device to hold the configuration for the Cyclone 10 GX FPGA. We are going to load a factory image and an application image into this memory, and...
WZ2
3 years agoHi,
ASMI Parallel IP currently does not have the discontinuance notification, which means Intel has not started planning its EOL.
About the second question about "Multi-master" for Generic Serial FLASH loader IP, you can implement the multi-master in your design. It is not implemented by the IP itself.
