17 years agoWrite in ext flash the fpga .sof + NIOS .elf with maxII conf. contr. + PLF
I have been used to store FPGA .sof configuration file + NIOS hex code into a serial conf device (EPCS64) using the NIOS-IDE flash programmer. Now I have a stratix III dev board on which a MAXII device is acting as a configuration controller. I have been application note 386 on how to use the PFL but have not yet found a clear set of instructions or an example, better yet, on how to use the PFL to store both the .sof and the.hex in flash ( along with the boot loader code) in such a way that the MAXII would properly configure the FPGA upon restart.
Information is needed on: - source code for the MAX controller - where does the MAX II config controller look for the start of a new custom configuration - how can I add the bootloader code in flash to copy the NIOS executable in RAM upon start thank You for your attention already and in advance for any useful hint.No RepliesBe the first to reply
