16 years ago
write char in DE2 SRAM
hello,
Sorry I'm a newbie in NIOSII...
I would like to write and read a char in the SRAM, I try to use itoa function but NIOSII doesn't recognize this function?
I use this command:
IOWR_16DIRECT((SRAM_BASE), 4, "a");
value = IORD_16DIRECT((SRAM_BASE), 4);
printf("%d,%s\n", 4,value);
How can I write a char in SRAM whithout itoa function please?
Thx.
    I've tested your code....
    I would like to know how you can read this char using IORD_16DIRECT ?
    How do you write a char as "abcd" at a specific adress ?
    Thanks for your help.
    ok thx i'll try it.
    I've one more question about that... what's the ".sram" ? cuz the sram that i use is a new component that i've created in SOPC builder...would like to know if this name should be linked with the name of the component....
    Thx
    For declaring an initialized string at sram use:
    char my_str __attribute__ ((section (".sram")))   = "abcde";
    my_str must be global. This, assuming you have a sram object.
    For copying between memory locations just use memcpy().
    if i wanna write a char for exemple "abcd" what can i do ?
    thx
    Non standard itoa() function is for convert an integer to a string, it is not related to SRAM,
    If you want convert numbers to string just use standard function sprintf().
    If you want write a single char, use simple quotes 'a', not double quotes "a".
