16 years agowrite char in DE2 SRAM
hello, Sorry I'm a newbie in NIOSII... I would like to write and read a char in the SRAM, I try to use itoa function but NIOSII doesn't recognize this function? I use this command:...
16 years agoNon standard itoa() function is for convert an integer to a string, it is not related to SRAM,
If you want convert numbers to string just use standard function sprintf(). If you want write a single char, use simple quotes 'a', not double quotes "a".
