12 years agoWorst case Tpd value changing
My simple programme tpd value is different from my previous compilation. Im using the same code and device family but dnt knw wats the cause of this variation. Previously had 5ns. Now im getting...
12 years agoYou may well see different results each time thanks to the way Quartus can use random seeds for compilation. More importantly, have you constrained your design? Quartus will aim to achieve the timing you require, providing you've supplied it. How important is the worst case tpd if the design meets your requirements?
Regards, Alex
