18 years agoWorking with LCD
Pardon how amateur this looks, I havent had much practice
Here is the code I wrote, as far as I can tell I've wired everything up as documented in the code, but when I try to run it, the bottom Blocks of the LCD go solid, like the other forums said should happen before it's initialized. But I see no response at the LCD. It may have looked neater if Freddy Krueger had soldered it, but I am pretty sure I didn't damage it. This is a standrd LCD from sparkfun. I am working with the Cyclone II starter Kit, and I am a reformed Visual Basic Person, so thats why I seem to write code a little different. Please tell me if anything you see would make this not work, or if you have any tips on how to do it more effeciently, I know it looks really amateur at this point. module LCD_PRINT(IOBUS,deb2,clk,STC); output [30:0] IOBUS; // output pins input [3:0] deb2; //debounce signal, I step through this with the buttons so I can test signals input clk; // standard clock from starter board (27mhz) reg [7:0] outc; // 8 bits going out to data db0-db7 reg RS; // register select input [3:0] STC; // STC count incremented from debounce, its on 7seg LCD for testing reg [16:0] count; // timer for leaving E high for a while, then shutting it reg writing; // reg for E on or off // debounce comes as a pulse from another module // this part generates my E writing signal to LCD // Simulation seems to work always@(posedge clk) begin if (deb2!=4'b0000 & count==0) begin count=1; writing=0; end if (count>0 & count!=1000) begin count=count+1; end if (count>200 & count !=1000) begin writing=1; end if (count==1000) begin count=0; writing=0; end //this segment sets output for each data sent, STC is count that is incrementd in the debounce module if (STC==1) begin outc=8'b00111000; // send 38h for 8 bit mode RS=0; end if (STC==2) begin outc=8'b00001111; // send 0Fh for "Display On" RS=0; end if (STC==3) begin outc=8'b00000001; // send 01h to clear RS=0; end if (STC==4) begin outc=8'b00001111; RS=1; end if (STC==5) begin outc=8'b01111111; RS=1; end if (STC==6) begin outc=8'b11111111; RS=1; end if (STC==7) begin outc=8'b01010101; RS=1; end end assign IOBUS[0]=0; // IOBUS[0]=R/W always at 0 for writing assign IOBUS[1]=RS; // IOBUS[1]= RS 0 for command, 1 for data assign IOBUS[2]=writing; // IOBUS[2]=RE assign IOBUS[3]=outc[0]; assign IOBUS[4]=outc[1]; assign IOBUS[5]=outc[2]; assign IOBUS[6]=outc[3]; assign IOBUS[7]=outc[4]; assign IOBUS[8]=outc[5]; assign IOBUS[9]=outc[6]; assign IOBUS[10]=outc[7]; endmodule _________________ It's good to be evilNo RepliesBe the first to reply
