SMude
3 years agoWoodward-Request for MDDS<179571>
Dear Team,
Greetings!!!
Can you please provide us the MDDS document for below listed devices. I was unable to find the same in MDDS database.
Mfr Part Number
EP1C4F400C8ESN ( N=PBFR...
Zawani_M_Intel
3 years agoHi SMude,
Thank you for using Intel FPGA Community Forum.
Please download your MDDS here :
https://www.intel.com/content/www/us/en/collections/content-type/mdds.html
You can the xml in excel by opening it via developer tool, see instructions below.
How to open xml file in Excel:
- Open a new blank Excel file
- Click on Developer tab, then click Import
- Select the xml file you want to import, then click Import
- Click "OK" on pop-op information, and also "OK" on where to Import data
- The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
- I recommend to delete column AK so that the other columns will display better.
Thank you!
Wani
SMude
3 years agoDear Wani,
Thank you, I am unable to find MDDS for these devices . Can you please attach these documents.
Note:- I followed all the steps you described. However no success.
- SMude3 years ago
Dear Wani,
